2006 misfiring cylinder #4
Old May 25, 2012 | 09:55 AM
markkovacic's Avatar
Default 2006 misfiring cylinder #4
My 2006 Pacifica started running very rough a couple of days ago and the engine light came on. The code reads P0304.
I had just changed the plugs two weeks ago (100,000 mile service) and was hoping that the new plug or the coil pack were bad. So, I pulled the #4 cylinder plug and it was gunked up very bad. I replaced the plug and put in a new coil pack in case it was not working.
After completing, I ran the car and within 5 minutes the same roughness was back. Pulled the coil pack and plug and the new plug was fouled badly. Looks like mud on the tip. This after only 5 minutes of driving. Also, i noticed the catalytic convertic was very hot, glowing in fact.
Can anyone point me in a direction? What should i try next?
Thank you for your time.
Old May 25, 2012 | 10:20 AM
TNtech's Avatar
Do a compression test
Old May 25, 2012 | 10:25 AM
Thank you. Can you explain what you think might be the problem and why a compression test is next? i just want to understand the thought process as i continue.
also, is this something i may be able to do? i am mechanically inclined. Do they sell the instruments at regular auto stores?
thanks for time!
Old May 25, 2012 | 01:04 PM
Is there a way to manually clean the valves? I see that this engine has some history with problems with valve seats.
can the carbon buildup be cleaned up?
Old May 25, 2012 | 11:36 PM
was this an issue b4 u replace the spark plugs ?
Old May 26, 2012 | 05:49 AM
No Sir, not a problem prior to me changing the plugs.
Old May 26, 2012 | 08:01 AM
then go back and check the plugs and coils and so on did u gap them did u use something other then champion?
Old May 26, 2012 | 09:40 AM
I used Bosch Platinum's +4....so i did not have to gap them.
i did change the #4 plug and coil pack after i got the P0304 code and i had the same result after 5 mins of driving.
Did i pull a dumbsh**t with the plugs? Should i replace all plugs with Champion and try again?
Could this have caused the #4 cylinder to misfire?
thanks for your time.
Old May 26, 2012 | 10:49 AM
I just went out and bought Champion Double Platinum's. I will install and see if things change. I will report back once this plug swap is done.
Old May 26, 2012 | 01:41 PM
TNtech's Avatar
A pic of that spark plug you described earlier might help.
