2007 Pacifica Touring Transmission Questions
Old Apr 22, 2010 | 02:28 PM
07RedPacificaT's Avatar
Default 2007 Pacifica Touring Transmission Questions
Hi
I have a 2007 Chrysler Pacifica 4.0 FWD w/ the 6-speed transmission. & shifts very hard through 1-2 gear. Dealer said that is normal, it’s the torque of the car. Are they right?
Also how do I check the transmission fluid without going to the dealer & have to pay $35 to have them check it.
Old Apr 22, 2010 | 02:35 PM
go test drive a van with the same 4.0 engine it will do the same thing. Inorder to check the fluid correctly u would need a scanner to check for trans temp and a special dip stick.
Old May 4, 2010 | 09:38 AM
SDHUSKER's Avatar
Default Sdhusker
I also have an '07 touring and early on had the same problem. There is a service bulletin out on the tourqe converter. Mine was replaced under warrantee and that corrected the problem. Shifts smooth now.
ajkostomaj
Sep 23, 2014 12:10 AM
Bullnugget
Jan 16, 2014 08:20 PM
NikoTes
Mar 4, 2013 08:44 PM
Txtaylor
May 17, 2012 07:45 AM
gator7
Dec 21, 2009 11:00 AM
