2007 Pacifica wheel hub replacement ABS
2007 Chysler Pacifica Touring 4.0L 167,000 miles. Replaced drivers front wheel bearing hub and now i have these waring lights: ESP/BAS, AWD!, ABS and traction control indicator. I had no issue with these systems prior to the wheel hub change. They showed immediately after starting the vehicle prior to driving. They still exists after test driving and a few start cycles. Now, i did have difficulty disconneting the ABS harness connection in the wheel well behind the splash gaurd. The wheel hub I purchased from O'reilly Auto Parts here in Michigan. The wheel hub is newer style with ABS harness attached. Should i drive the car for a while and through several start cycles for the computer to calibrate? I also will recheck the harness connection point that caused me difficulty. Should I disconnect and reconnect the battery for reset? Any ideas?
Thanks, Chuck |
might be wrong ones for that year or cheap part from china who knows but what you replaced would be the issue
Turned out to be the plug connection behind the splash guard was not fully engaged. Reconnected it and all lights went away.
