2007 Pacifica wheel hub replacement ABS
Old Feb 23, 2017 | 09:02 PM
Chuck Webb's Avatar
Default 2007 Pacifica wheel hub replacement ABS
2007 Chysler Pacifica Touring 4.0L 167,000 miles. Replaced drivers front wheel bearing hub and now i have these waring lights: ESP/BAS, AWD!, ABS and traction control indicator. I had no issue with these systems prior to the wheel hub change. They showed immediately after starting the vehicle prior to driving. They still exists after test driving and a few start cycles. Now, i did have difficulty disconneting the ABS harness connection in the wheel well behind the splash gaurd. The wheel hub I purchased from O'reilly Auto Parts here in Michigan. The wheel hub is newer style with ABS harness attached. Should i drive the car for a while and through several start cycles for the computer to calibrate? I also will recheck the harness connection point that caused me difficulty. Should I disconnect and reconnect the battery for reset? Any ideas?
Thanks,
Chuck
Old Feb 24, 2017 | 10:32 PM
might be wrong ones for that year or cheap part from china who knows but what you replaced would be the issue
Old Feb 27, 2017 | 06:11 PM
Chuck Webb's Avatar
Turned out to be the plug connection behind the splash guard was not fully engaged. Reconnected it and all lights went away.
jay800
May 2, 2015 11:46 AM
Bojib
Apr 11, 2015 11:28 AM
travelmad
Aug 28, 2013 04:36 PM
svtcop
Feb 27, 2013 02:38 PM
Vasiliki-Greece
Jun 12, 2009 06:34 AM
