2008 4.0L Slight water pump leak
Old Mar 17, 2016 | 04:33 PM
davisyk's Avatar
Default 2008 4.0L Slight water pump leak
I have a 2008 limited with 127k miles. At 101k I changed timing belt water pump tensioner pully and hydraulic tensioner (was leaking oil). It has had a slight coolant leak every since (a few ounces a week). Since this was a year and half or so ago I can't really remember if I torqued the water pump bolts tight enough. Question - do I have to pull everything off again (including the harmonic balancer to get the bottom timing cover off) to be able to access all water pump bolts to re-torque? While I am in there I was going to put an air compressor on the cooling system no make sure that fixes the problem. If not another water pump. Some folks said get the OEM. I got the AC Delco from rockauto.com. Seemed like a quality unit. Maybe my mistake.
The other question. What if I just leave it as is for the next 75k miles? Certainly would not have to change antifreeze since I would be adding fresh all the time. Say a few ounces a week x 52 weeks x 3 more years would be no more that 4 / 5 gallons of premixed antifreeze. I am not sure if this would damage the timing belt.
Dave
Old Mar 27, 2016 | 09:57 PM
cirrus98's Avatar
You will have to pull everything off the re-torque the bolts. There is no getting around it.
Old Mar 28, 2016 | 12:00 PM
davisyk's Avatar
I was afraid of that. Thank you.
snowbird2006
Dec 1, 2014 01:01 PM
farmerbob02
Apr 13, 2011 12:04 AM
dmbeale
15
Nov 24, 2010 06:26 PM
captain catfish
Oct 2, 2010 04:32 PM
touch down
Aug 27, 2009 09:20 PM
