2008 Pacifica rear AC problems
Old Jul 25, 2016 | 07:39 PM
T3knik's Avatar
Default 2008 Pacifica rear AC problems
I am having a rear AC issue with my 2008 Crysler Pacifica. When I turn on the AC it blows air fine in the front. However only cold air blows in the floor air vents in the rear of the vehicle and not through the middle console vents. I tried messin with different settings and no matter what I try no air will blow out of the center vents only the floor vents in the rear of the vehicle. This also is the case for heat as well. Any suggestions?
Old Jul 25, 2016 | 09:23 PM
probably a mode door motor in teh back. The panel will need to come off to get access to it.
Old Jul 25, 2016 | 10:25 PM
T3knik's Avatar
Where do I access the mode motor and which one do I need to look at replacing, isn't there several?
Old Jul 26, 2016 | 09:56 PM
a service manual will assist you in doing such a task
GoJu
Jan 18, 2016 12:28 PM
mchunter
Nov 2, 2011 07:42 AM
Thomasx
Jul 26, 2011 02:22 PM
Suzanneschillaci@comcast.net
Feb 15, 2011 11:23 AM
DavidInNH
Jan 29, 2009 07:33 AM
