2020 Pacifica - loose underbody pan shield
I love my 2020 Pacifica S, with 71K fairly problem-free miles, so far.
Recently, an under-body panel has come loose & is dragging underneath.
Located at the midpoint, front-to-back, spanning the width of the vehicle.
It appears to be part of the Under Body Protection group, item 10, 68250634AD.
It's also labeled as an acoustic shield.
It isn't covered by the MVP plan (not a mechanical item), so I have to deal with it.
$247.52 discounted part, plus labor to remove the old then install the new one... dang.
I'm sure this is happening to others - what did you do ?
Will it stay up with new retaining pins? If not, tie it up with pull-ties ?
Or ? Appreciate knowing your experience & advice, thanks in advance - Den
