3.5l timing belt videos or pics or instructions?
Old Aug 20, 2014 | 01:07 PM
jimmy154's Avatar
What are the water pump and everything else I have to put on torque specs?
Old Aug 20, 2014 | 05:21 PM
jimmy154's Avatar
Default Timing is off, but I guess the belt will stretch a little?
Pulley on the right is off by 1/7 of a tooth (as far as I can tell) and pulley on the left is off by 2/5 (or almost half) of a tooth. Bottom gear is more or less spot on.
If the belt stretched a little over time, it should be spot on, no?
There's a "04" stamped on the water pump.
Was it made in 2004?
Can you tell when the hydraulic tensioner was made?
I assumed the water pump should be torqued to 105 in/lbs or 8.75 ft/lbs or 28 Nm. I also used Loctite 271 (red) on the bolts.
Attached Thumbnails 3.5l timing belt videos or pics or instructions?-100_7784.jpg   3.5l timing belt videos or pics or instructions?-100_7785.jpg   3.5l timing belt videos or pics or instructions?-100_7786.jpg   3.5l timing belt videos or pics or instructions?-100_7777.jpg   3.5l timing belt videos or pics or instructions?-100_7783.jpg
Old Aug 28, 2014 | 05:05 PM
jimmy154's Avatar
Default Where do these go?
Where do these go?
I put everything together except for the inner wheel well and these are extra.
The AC has a couple, but they are on there and I don't think the AC came with any nuts.
The timing belt has a couple and they are on and they are 15 mm, I think.
These are 13 mm and I don't know where they might go.
Does anybody know?
I did the timing belt, AC and front and right engine mounts.
I had to take the radiator fan and power steering off to do this.
I also changed the high pressure power steering line.
Attached Thumbnails 3.5l timing belt videos or pics or instructions?-100_7921.jpg
Old Aug 28, 2014 | 08:18 PM
cirrus98's Avatar
1st, I hope you're water pump doesn't go anytime soon. You need high heat to ''loosen'' the Loctite. Given that the heat required might be higher than what the engine produces, on a aluminium assembly, that doesn't sound too good. As for your camshaft sprockets being off just a bit, I wouldn't worry too much. When I did mine, the rear one was just to say off. But my TDC was done before removing the belt, and it turned out fine. The 2 extra nuts/washers, are they not from the 2 threads that stick out the water pump plate towards the rear of the engine??????
Old Aug 28, 2014 | 10:15 PM
  #15
jimmy154's Avatar
I'm hoping the water pump plate is the same thing as the timing belt cover?
The two nuts on the timing cover are there, but it's really strange I have two nuts left over.
I also lost two power steering pump bolts and two power steering reservoir bolts even though I thought I was really careful and put all the bolts in 3 zip-lock bags
Old Aug 30, 2014 | 11:08 AM
  #16
jimmy154's Avatar
I think I used the power steering bolts in the AC compressor.
My old compressor has studs not bolts. That is why I had extra nuts and was missing 2 power steering bolts.
Now I need to quiet down the alternator.
It puts out 13.8 VDC and is pretty loud.
Is 13.8 too low? Battery is 12.8 VDC.
Sounds like a bearing.
Chrysler Forum Editor
Dec 14, 2012 07:18 PM
Nov 14, 2012 06:08 PM
Oct 9, 2012 01:28 PM
toovo1985
May 4, 2010 11:56 AM
Mar 23, 2006 05:00 AM
