adding headrest monitors, but have premium 6-disc dvd already
Old Mar 26, 2010 | 10:11 PM
  #21
Jake103's Avatar
Originally Posted by pac2006
The all in one is a different connector, but I can get it and make it if you like. I will have to do a little research first. Also can you take a pic of the pinout on the top of your unit.
Hello,
I have a pic. Can you please email me your email address?
I don't have access to it thru the site.
Thank you for your help and for the reply.
Jake103@comcast.net
Old Mar 26, 2010 | 11:47 PM
  #22
mrfixit454's Avatar
The DVD Changer has a 12 and 16 pin connectors too. Maybe they will be the same.
Old Mar 27, 2010 | 10:48 AM
  #23
Jake103's Avatar
Hello,
Here is a pic of the pinout.
Thanks,
Jake103
Old Mar 27, 2010 | 03:00 PM
  #24
mrfixit454's Avatar
Looks like the DVD changer is slightly different but with the correct 12 pin plug and pins 5,6, and 12 from the picture you provided, Pac2006 should be able to fix you up. but let him decide the correct pins as he has done this before.
Below is the 2004 Pacfica Changer
CAV CIRCUIT FUNCTION
1 X114 20GY/TN FUSED B(+)
2 X211 20YL/GY IGNITION RUN/ACC SIGNAL
3 -
4 -
5 X915 22GY/LB VIDEO CONTROL
6 X515 22GY/OR VIDEO SIGNAL
7 X530 20GY/DB VIDEO RETURN
8 -
9 X555 22VT/OR VIDEO PLAY SIGNAL
10 -
11 -
12 X955 22 SHIELD
Old Mar 27, 2010 | 08:09 PM
  #25
pac2006's Avatar
I am thinking the 16 pin is the one that goes to the dvd changer, and the 12 pin is only used if you don't have the changer and it goes directly to the screen. My email is laundrydude@comcast.net
I think the all-in-ones were available in the 2007-2008 models. Do you have the changer also?
Old Mar 27, 2010 | 11:39 PM
  #26
Jake103's Avatar
Hello,
No, I don't have the changer, just the all in one.
Thanks,
Jake103
Old Mar 31, 2010 | 10:55 PM
  #27
pac2006's Avatar
I just ordered 4 of the Mopar plugs to make the adapters. If anyone needs one, let me know.
Old Apr 6, 2010 | 01:10 PM
  #28
desperado's Avatar
that seems to be the same configuration of plug/pins as I have in my setup.
Old Apr 18, 2010 | 10:50 PM
  #29
srdugan's Avatar
Default Adaptor
PAC2006, trying to email you but this forum says i don't have the right permissions to send you a note.
Interested in seeing if you can rig an adaptor for my 6-disc changer in my 2005 T&C.
email me please and we can talk specifics, thanks:
srdugan@gmail.com
Old Apr 30, 2010 | 10:03 PM
  #30
Jake103's Avatar
Default LCD ceiling mount screen template
Hello,
Trying to mount an aftermarket LCD screen overhead in my Pacifica.
Anyone have a template to help me position the screen? I really don't want to take down the headliner.
Any help will be appreciated.
