Advice needed-- Clicking noise when stepping on brake
I replace the brake light bulb and ever since, there is a clicking noise when I step on the brake while the car is in "Park". The noise is a clicking sound that is coming from under the gear shifter. Does anyone know what is causing this?
There is a shifter interlock solenoid in the center console. You cannot move out of park without your foot on the brake. The noise you are hearing is the interlock releasing when you step on the brake. Totally unrelated to changing the bulb
Thanks-- it was just coincidence that this noise just started happening after I replaced the bulb. Since this noise had never happened before I'll make an appointment with the dealership to get it looked into.
Originally Posted by SanDiegoPac
(Post 30248)
Originally Posted by Sierrasan
(Post 30289)
Your going to waste your money. This sound is normal.
