Alignment Specs
Old Sep 12, 2012 | 11:27 AM
Victor L's Avatar
Default Alignment Specs
Does anyone have the alignment specs for a 2005 Pacifica AWD Touring model? I have an 04 FSM but there are no specs published in the manual.
Old Sep 12, 2012 | 11:38 AM
it wont be in a manual because u would use the specs given on the 8000.00 machines used to align the car.
Old Sep 12, 2012 | 11:49 AM
Victor L's Avatar
OK. Do you know the specs listed on the 8000.00 machines?
Old Sep 12, 2012 | 12:19 PM
nope wont do u any good unless u have the machine handy what are u trying to do any way? U cant do an alignment with out the machines
Old Sep 15, 2012 | 12:19 AM
sivitec's Avatar
@Victor>> Here's the specs that you requested. You can give this to your aligner if they don't have the specs of your car.
"FRONT WHEEL ALIGNMENT"
CAMBER
[PREFERRED:] -0.20°
[ACCEPTABLE:] -0.60° to +0.20°
Cross-Camber
(Maximum side-to-side difference)
[PREFERRED:] 0.00°
[ACCEPTABLE:] 0.50°
CASTER*
[PREFERRED:] +4.50°
[ACCEPTABLE:] +4.00° to +5.00°
Cross-Caster
[PREFERRED:] 0.00°
[ACCEPTABLE:] +1.00°
TOTAL TOE**
[PREFERRED:] 0.10°
[ACCEPTABLE:] -0.10° to +0.30°
[PREFERRED:] 0.00°
[ACCEPTABLE:] -0.06°
"REAR WHEEL ALIGNMENT"
CAMBER
[PREFERRED:] -0.40°
[ACCEPTABLE:] -0.90° to +0.10°
Cross-Caster
[PREFERRED:] 0.00°
[ACCEPTABLE:] +0.50°
TOTAL TOE**
[PREFERRED:] 0.10°
[ACCEPTABLE:] -0.02° to +0.22°
THRUST ANGLE
[PREFERRED:] 0.00°
[ACCEPTABLE:] -0.20° to +0.20°
Notes:
* For reference only. These are non-adjustable angles.
** TOTAL TOE is the sum of both left and right wheel toe settings. TOTAL TOE must be equally split between
each front wheel to ensure the steering wheel is centered after setting toe. Positive toe is toe-in and negative toe
is toe-out
Old Oct 11, 2012 | 11:35 AM
Victor L's Avatar
Thanks for the specs provided. This helps a lot when changing steering components like tie rods and racks. I set the toe just like the old school racers do... with string line and a good understanding of algebra. I've always have been within accept ranges when double checked at an alignment shop. I can check camber in my drive also but camber really doesn't change unless there is trauma to the car like an accident.
Old Jul 17, 2017 | 10:06 PM
Leon Perkins's Avatar
I just went on group-on and got 6 month 4 wheel alignment for $59. I was going to it myself however for the price I couldn't beat it.
mrdwkds
Jan 23, 2009 07:27 PM
jquinones
Apr 22, 2008 07:29 PM
mbar
Dec 1, 2007 11:13 PM
redpac
Aug 8, 2007 07:12 PM
pit0203
Feb 24, 2006 11:00 PM
