Analog Clock in '04 Pacifica
Old Jan 11, 2011 | 02:11 PM
aprijan247's Avatar
Default Analog Clock in '04 Pacifica
Is it possible to change the battery in the analog clock on the 2004 Chrysler Pacifica? Or does the entire assembly need to be changed? If so, how do you change it
I recently set the right time on the clock but it is not keeping the correct time.
Old Jan 11, 2011 | 04:43 PM
there is not a battery for it its powered off the cars system if its bad more then likely need to replace it.
Old Jan 11, 2011 | 05:26 PM
Djinn-n-Tonic's Avatar
Does it not work at all, or just loses time?????
Look at your owners manual, there is a "CALIBRATION PROCEDURE" to correct for gain/loss of time.
A word to the wise, the typical cause of loss of time is a "Low System Voltage"....Expect to change a battery soon.
Old Feb 9, 2011 | 07:30 AM
aprijan247's Avatar
Default Clock Issue
Thanks for your responses. Somehow, the clock is keeping the correct time now!
Emtronics
Aug 22, 2009 10:54 PM
vivsor
Feb 3, 2009 03:44 PM
redbelair
Aug 7, 2008 06:59 AM
Dustymedic
Mar 21, 2008 02:07 PM
Hawwk11
Feb 25, 2007 03:24 AM
