blowing air problem
Old Apr 7, 2012 | 09:07 AM
adouglass's Avatar
Default blowing air problem
My 2005 air blower will not shut off. Temp controls work fine and I can switch between hot and cold air, I just cannot shut the blower off, and once in awhile it will stay on when the car is shut off. What might becausing this? Any and all help is greatly appreciated!
Old Apr 7, 2012 | 09:10 AM
more then likely the blower motor resistor assembly
Old Apr 7, 2012 | 09:27 AM
adouglass's Avatar
Is that an easy fix? Or should I look at taking it to a shop?
Old May 6, 2012 | 06:46 PM
haio's Avatar
Did you get this problem solved?
I have the same problem. The blower comes on at maximum speed when I turn on the ignition and stays on until The ignition is turned off again. Sometimes it stays on for a while more(and also the climate display), but I guess this is a normal dry out routine as it did this from time to time before also.
I thought it was related to another "power issue" I have. But maybe not? I think I will check out the resistor assembly as well.
Old May 7, 2012 | 08:09 PM
haio's Avatar
It turns out that my PAC does have a "blower power module". This is a Pulse With Modulated(PWM) electronic (MOSFET) fan speed controller and not an ordinary resistor assy.
For sure this was the reason for the fan not stopping like Chrysler Tech said. The fan was running full speed even with the PWM controll wire disconnected. Trying an attempt to repair the module tomorrow. If it does'nt work out I`ll have to get a new one.
Changing this module is an easy fix if you did not already get it repaired. Placed behind the glove compartment.
Old May 8, 2012 | 07:57 AM
haio's Avatar
At least one of my problems solved. Changed the MOSFET(powerstage) of the "blower power module." 6$, 15 min fix. Works like a charm.
rsdodo
Sep 25, 2025 09:57 AM
BARCLAY
May 19, 2010 04:57 PM
Chrysler300MSpecial
Dec 6, 2009 07:51 PM
bjbrunk
Feb 5, 2009 08:35 AM
glock 40
Apr 30, 2008 10:58 PM
