View Poll Results: I have bled lines and calipers on all 4 wheels, all air is out. Brake pads are good.a
0%
sf
0%
Voters: 0. You may not vote on this poll
Brake pedal won't stay firm when pressed
Old Dec 14, 2021 | 09:33 AM
macsnip@gmail.com's Avatar
Default Brake pedal won't stay firm when pressed
I have bled all calipers, starting with the passenger rear, and worked toward the master cylinder. All air is out of lines, no leaks, and brake pads are good. Still have a soft pedal when pressed. Could it be the master cylinder, diaphragm, or vacuum leak?
Old Dec 15, 2021 | 09:34 AM
If the engine is running, you will be able to press the pedal all the way to the floor. This is normal. Try it with the engine stopped. Pump several times to use up all the vacuum in the booster. After several pumps the pedal should be very firm.
Old Dec 16, 2021 | 07:51 PM
brian3's Avatar
I have never heard it is ok for the brake petal to go to the floor with an engine running, in fact just the opposite.
lucass1428
Aug 5, 2019 12:39 PM
ReluctantMech
Feb 11, 2018 07:17 AM
tmacky34
Cirrus & Breeze
Sep 22, 2016 09:17 AM
Mark
Dec 10, 2014 09:13 AM
mark34050
Mar 23, 2014 12:00 AM
