A/C drain line location
Old Dec 12, 2017 | 10:46 PM
Barbara 2's Avatar
Default A/C drain line location
Normally our '04 Pac drips down below the dash area nearer the center of the car underneath. Something has clogged it causing the water to flood the passenger side floor carpet front to the back. Up on a lift today no drain hose was seen. It must be behind the metal heat shields that are screwed to the floorboards. It is not on the outside of the firewall on the passenger side down low as some mention because that is the sunroof drain. With the under dash trim panels removed it isn't seen either. Could someone please help with the location ? Thanks. *BW*
swright227
Dec 10, 2018 05:08 PM
7Enigma
13
Nov 16, 2014 01:24 AM
Jan 12, 2007 09:59 PM
latreto
Nov 28, 2006 10:47 PM
redriderbob
Dec 18, 2004 12:48 PM
