A/C Problem
Old Jun 30, 2007 | 10:31 PM
Default RE: A/C Problem
no i mean a control issue control as in what tells the pcm that its ok to turn on the clutch. Either the pcm,pressure switch or IPM which is the fuse box.
Old Jul 24, 2007 | 11:50 AM
cwu's Avatar
cwu
Where is the location of a/c cabin filter? I could not find it around the tool box in passenger side.
Old Jul 24, 2007 | 11:55 AM
then u might not have one not all of them have one.
Old Jul 24, 2007 | 12:01 PM
cwu's Avatar
cwu
Many thanks. My 99 LHS gets bad smell from the ventilations. I figured out the problem by replacing the a/c filter on my other cars. Any advise?
  #15
cwu's Avatar
cwu
Old Jul 24, 2007 | 04:06 PM
  #16
Your in a PAC forum not an LHS forum They either leak at the evap and or grow mold in there as well. Chrysler has some stuff u put into a spray can that will kill and coat the evap coil. If u cant do this or it does nto work put a new evap coil in.
Old Jul 25, 2007 | 10:15 AM
  #17
cwu's Avatar
cwu
Great appreciate! Sorry for put it in wrong forum.
Then I may either use mold remover or Chrysler stuff. But how to approch the evap coil.
I don'tinitialize the issue in LHS forum but like to have your input.
My best,
Old Jul 25, 2007 | 03:30 PM
  #18
approch the evap coil.???? u mean get to it? there is a tube that will come with it u apple it to a pressure system air or what ever and spray it into the evap area on the coil.
Old Jul 25, 2007 | 05:00 PM
  #19
cwu's Avatar
cwu
I mean where to spary the lysol or mold remover into.Can the tube be located under car, the passenger side?
Thank you!
Old Jul 25, 2007 | 05:01 PM
  #20
no the tube is a chrysler part and u remove some stuff to get right to the coil.
