Camber Bushings
Hello,
I need to replace my Camber bushings but RockAuto sells Different styles. Chrysler is clueless on the parts.What are the differences and how do they affect ride? Thanks :) RAYBESTOS Part # 6111193 Professional Grade Rear Upper; Eccentric Bushing; Replaces 41.5mm Outside Diameter Bushing; Plus Or Minus 3/4 Degree Camber ACDELCO Part # 45K0199 {#19186947} Professional Rear Upper; Eccentric Bushing; .5 mm O.D. Bushing; Camber Plus or Minus 1-1/2 Degrees RAYBESTOS Part # 6111194 Professional Grade Rear Upper; Eccentric Bushing; Replaces 41.5mm Outside Diameter Bushing; Plus Or Minus 1-1/2 Degree Camber ACDELCO Part # 45K0198 {#19186946} Professional Rear Upper; Eccentric Bushing; .5 mm O.D. Bushing; Camber Plus or Minus 3/4 Degrees RAYBESTOS Part # 6115030 Professional Grade Rear Upper; Up To Plus / Minus 1-1/2 Degree Camber; Replaces 39.5mm / 41.5mm Outside Diameter Bushings Part Image CAD$45.32 ACDELCO Part # 45K0194 {#19161720} Professional Rear Upper; Eccentric Bushing; .5 mm O.D. Bushing; Camber Plus or Minus 1-1/2 Degrees ACDELCO Part # 45K0193 {#19161719} Professional Rear Upper; Eccentric Bushing; .5 mm O.D. Bushing; Camber Plus or Minus 3/4 Degrees |
