Camber Bushings
Old May 31, 2014 | 08:09 AM
soulpoehl's Avatar
Exclamation Camber Bushings
Hello,
I need to replace my Camber bushings but RockAuto sells Different styles. Chrysler is clueless on the parts.What are the differences and how do they affect ride?
RAYBESTOS Part # 6111193 Professional Grade
Rear Upper; Eccentric Bushing; Replaces 41.5mm Outside Diameter Bushing; Plus Or Minus 3/4 Degree Camber
ACDELCO Part # 45K0199 {#19186947} Professional
Rear Upper; Eccentric Bushing; .5 mm O.D. Bushing; Camber Plus or Minus 1-1/2 Degrees
RAYBESTOS Part # 6111194 Professional Grade
Rear Upper; Eccentric Bushing; Replaces 41.5mm Outside Diameter Bushing; Plus Or Minus 1-1/2 Degree Camber
ACDELCO Part # 45K0198 {#19186946} Professional
Rear Upper; Eccentric Bushing; .5 mm O.D. Bushing; Camber Plus or Minus 3/4 Degrees
RAYBESTOS Part # 6115030 Professional Grade
Rear Upper; Up To Plus / Minus 1-1/2 Degree Camber; Replaces 39.5mm / 41.5mm Outside Diameter Bushings
Part Image
CAD$45.32
ACDELCO Part # 45K0194 {#19161720} Professional
ACDELCO Part # 45K0193 {#19161719} Professional
nutinph
Feb 12, 2011 06:11 PM
jquinones
Apr 22, 2008 07:29 PM
latreto
Mar 11, 2007 02:52 PM
rickey1172
Oct 18, 2006 03:03 AM
ChryslerNamedTrixie
Oct 21, 2005 05:03 AM
