clicking in transmission?
I have a 2005 Pac and I get a clicking noise everytime I accelerate or decelerate. Its sounds like it is coming from the transmission. Any help or advice would be appreciated
AWD??
There is a Service bulletin for Axle Nut Torque and Isolation washer installation.... If that doesnt cure it, The noise is likely coming from PTU..(Transfer Case). |
it is a FWD !
Ok....
Have you had motor mounts or axles Replaced recently...... Check the torque on the axle nut. A click, Snap Or Pop, can be caused by the splines on the axle shifting in the hub, or by poor contact of the hub and shaft face. Stay Tuned...I'll try and get you the TSB number. |
I had the motor mounts replaced about 1 1/2 yrs ago !!!!!!
