Code P0305 and P2314
Old Mar 24, 2013 | 10:37 AM
ThePacLady's Avatar
Unhappy Code P0305 and P2314
Misfire cylinder #5
New coils,new injector,alternator,Camsensor,Cranksensor.......Wh at else???
Old Mar 24, 2013 | 02:34 PM
Compresson test.
Old Mar 24, 2013 | 04:04 PM
ThePacLady's Avatar
Had a compression test and that's ok.
Old Mar 25, 2013 | 04:59 PM
Djinn-n-Tonic's Avatar
Year????? Engine size????
Why no mention of Spark plugs being replaced???? I cant believe anyone would diagnose a misfire without checking the plugs FIRST. At very least, the one on the affected cylinder.
#1......You CANNOT use aftermarket Ignition coils...The resistance is different...You MUST use the proper MOPAR coil.
#2,,,,,,Champion Spark plugs are a MUST......No bosch, no Splitfire, no E3's , No Autolites.
The system was designed to work around what the factory used. any deviation WILL WREAK HAVOC.
Old Mar 25, 2013 | 05:21 PM
I second that
Old Mar 26, 2013 | 03:44 PM
ThePacLady's Avatar
The year is 2005. Yes did replace all the spark plugs with NGK Laser platinum. It's 3.5 and brand new coils from the Dealer "SIR". And BTW theres no Negtive pulse.
Old Mar 26, 2013 | 03:50 PM
ThePacLady's Avatar
There's no negative pulse on cylinder #5.
Old Mar 26, 2013 | 05:19 PM
Ahh...Thats different. You are either looking for a wiring problem, or a Bad PCM.
You need to check wiring continuity and resistance between pin 2 of connector c2, and the #5 coil.
Old Mar 26, 2013 | 05:22 PM
busboy4's Avatar
#2,,,,,,Champion Spark plugs are a MUST......No bosch, no Splitfire, No Autolites.
Thanks. Good little nugget of info.
Old Mar 26, 2013 | 05:45 PM
ThePacLady's Avatar
I was just cking the wires and there fine. But something caugt my eye. When I was chking the negative pulse it was there then it just went away. Came back and away again. Just for a few seconds. The cars starts fine.
