Condenser replacement in '08 Pacifica
Old May 16, 2016 | 09:57 AM
ScAndal's Avatar
Default Condenser replacement in '08 Pacifica
Background: AC stopped working, found massive hole in condensor. System completely empty of refrigerant.
I pulled the front end off and removed the condenser and have a new one on order including replacement drier.
Question I have is, can I just recharge it myself after getting everything put back together? Any benefit of having the shop add 24oz for me?
Old May 17, 2016 | 11:47 AM
when a shop does it they put a vac on the system and removes any moisture in the system. its will them be the correct efficiency that is needed. if you do it yourself it will be fine just might not be as cold.
metalman3
Nov 5, 2015 05:33 AM
brad4567
Jul 1, 2013 09:49 AM
Kaysvan
14
May 30, 2013 09:33 AM
simlarock
Apr 30, 2011 10:55 AM
cserbantez
Jul 18, 2009 02:54 PM
