Extra Key
Old Dec 17, 2007 | 12:09 AM
betrowbridge's Avatar
Default Extra Key
When I purchased my '04 Pacifica I didn't realize the extra remote keys were so expensive, and I only got 1. Is it necessary to get another remote key if I'm looking to add remote start, or am I safe buying an aftermarket transponder key that is less expensive? Also, can the dealer program the transponder key with only 1 original or will I be stuck going with the $95-$120 remote/transponder key? Thanks for the help.
Old Dec 17, 2007 | 09:09 PM
Krmnnghia's Avatar
Default RE: Extra Key
You should be able to have your installer program your factory key to control the remote start. This is how mine was done. I push the lock button 3 times on the key and it starts the car. My unit is a Directed Remote Start. Tell your installer you want it setup this way then you don't have to worry about it.
Be prepared to pay for alot of extras...they may have to get into the doors, run an extra, thicker power wire as the factory ignition wire is too thin. Also the bypass system can be anywhere from $80-$140. Best Buy quoted me $400 for their cheapest unit and I fortunately went elsewhere.
jpenrose
Jul 21, 2014 03:14 PM
ma210
Oct 1, 2010 09:56 PM
bjushute
Apr 28, 2010 08:55 AM
Bajavicki
Dec 22, 2005 05:14 AM
JXI101
Dec 4, 2005 12:39 PM
