HID Installation Problem, HELP!
Old Apr 8, 2009 | 01:38 PM
pdot617's Avatar
Default HID Installation Problem, HELP!
Hey Pacificers lol
I installed HID's on my Pacifica 05 and the driver side is not turning on now... Its not the bulb! Im trying to figure out if i need to hook it up a different way or what. We tried to find the headlight fuse but nothing.
I need to know what i need to do or if i need to install it differently. It did work for a couple of months... Help! chrysler chargin 90$ "JUST" 2 find out what it is! wow.....
The HID's are installed the regular way. The only thing i can say is that the light use 2 stay on after i turned of the car but it would go off after 2 minutes. I dont think its sopose 2 do that with this kind of pacifica...
this my truck here: http://www.cardomain.com/ride/3073250
Old Apr 8, 2009 | 02:02 PM
wv53's Avatar
well mate nice car you got there!
wish i could help ya mate but i'm still trying to get my interior lights working, still chasin down gremlins! lol
good luck mate
Old Apr 9, 2009 | 10:21 AM
PacificaBus's Avatar
Is this a plug and play kit that you bought? I need more info. Are you using a harness?
Old Apr 16, 2009 | 09:58 PM
dalbery's Avatar
How funny is that. I was just in the process of figuring out if there was a fuse for this very problem. I have an 06 Pac that I've had an hid kit in for 10 months. Right side headlight quit working. I tohught it was blown so I ordered 2 new ones. That didn't fix the problem. I also have 2 new control units so I switched them in and out and tried all 3 bulbs. Nothing worked. We are not getting power to our drivers side low beam head lamp. I too would like to know what the heck is causing this. Please keep me in the loop. If I can figure it out I'll post the cure.
Thanks,
Darrell
Old Apr 17, 2009 | 06:20 PM
kevex's Avatar
I had the same problem on my 05. I narrowed it down to the light not getting enough power from that harness(mine was the driver side, getting 3-5volts only)and this was after I had them in for 7-8 months. What I did is used a relay wired to the battery and switched on by the pass. side headlight harness. I haven't had any problems since(1+yr.)
Hope that helps you guys any
Kevin
Old Apr 22, 2009 | 09:35 PM
pac2006's Avatar
I don't have the HID lights but have read alot about them. All the ones I read about mention the module that the lights connect to being different and needs to be changed also. If I can find the info I will post more, but if you only change the lights, they will work but with intermittent problems.
azaspen
Sep 26, 2014 03:47 AM
faltagracia
Sep 1, 2009 02:06 PM
sonic gihad
Jan 27, 2009 08:29 AM
calypso47
Oct 5, 2007 08:35 AM
ettienne
Jun 23, 2007 04:36 PM
