High Idle Speed issue (Pacifica 2005 3.5L)
Old Jan 22, 2019 | 12:00 AM
amivo's Avatar
Unhappy High Idle Speed issue (Pacifica 2005 3.5L)
Hi to all! I urgently need your help. I replaced the spark plugs on my Chrysler Pacifica 2005 3.5 L. After that, I tried to start the car. It started up but with very high idle speed. After a couple of seconds, the car turned itself off. Every time I start the car, this problem repeats. All hoses checked and bolts spun. Any idea? Maybe I damaged the sensors?
Thanks a lot in advance
Alex
Old Jan 22, 2019 | 11:13 AM
djetelina's Avatar
There is a Mass Airflow Sensor mounted on the black rubber air intake tube. It can be easily damaged (or left out) when doing the plugs on a 3.5. Can you verify MAF sensor is in place and functional?
Old Jan 22, 2019 | 11:28 AM
amivo's Avatar
I am not sure..
but I figured out that U have a bad vacuum leak where egr tube goes into upper intake... missing gasket.
amivo's Avatar
Originally Posted by amivo
I am not sure..
Sorry. I have
Old Jan 22, 2019 | 07:33 PM
djetelina's Avatar
Sorry. I have
Yes, the missing EGR gasket could do it. Either that or the MAF sensor leaking vacuum, causing the engine to rev up...
Old Jan 22, 2019 | 07:47 PM
amivo's Avatar
thank you. I will try to fix it with the gasket first. Did you mean MAP sensor?
Old Jan 22, 2019 | 08:28 PM
amivo's Avatar
f... ! Gasket doesn’t help... I will buy the MAP SENSOR
Old Jan 22, 2019 | 10:26 PM
amivo's Avatar
new gasket, new MAP sensor... but the same problem
Old Jan 23, 2019 | 06:34 PM
djetelina's Avatar
Not sure at this point. May try a good scan tool to see it it is throwing any codes...
Old Jan 23, 2019 | 09:03 PM
brian3's Avatar
OEM plugs or an alternative?
