How to install outside mirror
Hello,
My wife managed to do what I thought was impossible: break the passenger side mirror exiting our garage. Got a new mirror but would like to try installing it myself. Where could I find a manual explaining how to do that?
I appreciate all your help.
Thanks a lot!
Thanks a lot!
[ol][*]Using a trim stick C-4755 or equivalent, move the front door frame molding. (Refer to 23 - BODY/DOOR - FRONT/MOLDING - REMOVAL).[*]Remove door trim panel and water dam. (Refer to 23 - BODY/DOOR - FRONT/TRIM PANEL - REMOVAL).[*]Disconnect the electrical connector, if equipped (MIRROR WIRE CONNECTOR).[*]Using a trim stick or equivalent, remove the mirror flag stuffier.(FOAM STUFFIER).[*]Remove the nuts attaching mirror (SIDE VIEW MIRROR).[*]Remove the mirror from the door[/ol]door trim panel
[ol][*]Release door latch and open door.[*]Lower door glass.[*]Open remote handle trim plug and remove screw from behind inside remote handle (REMOTE HANDLE TRIM PLUG).[*]Open armrest pull cup trim plug and remove screw from inside arm rest pull cup (DOOR TRIM PANEL).[*]Disengage push-in fasteners attaching trim to door panel around perimeter of trim panel.[*]Tilt trim panel outward to clear locator pins on backside of trim panel.[*]Disconnect trim panel from retainer channel in inner belt weatherstrip at top of door by lifting while gently jiggling. CAUTION: Do not allow door trim panel to hang by the wire connector or wiring.[*]Move top of trim panel away from door, while supporting bottom trim panel.(DISCONNECT DOOR TRIM PANEL).[*]Disconnect inside handle cable end from clip, and pull conduit end out from bracket (FRONT DOOR TRIM PANEL MECHANICAL CONNECTIONS).[*]Disconnect lock **** conduit end from bracket. Slide cable barrel end out from the lock **** and guide cable through slot. Ensure that lock **** cable did not get bent (FRONT DOOR TRIM PANEL MECHANICAL CONNECTIONS).[*]Disconnect wire connector from power door lock switch, mirror switch, power window switch, and courtesy lamp.[*]Remove trim panel from door. [/ol]
canion1970
Mar 18, 2011 02:42 PM
Nov 15, 2006 02:24 PM
