How to Power Pacifica Gauge Cluster?????????
Tried to power this gauge cluster with 8 aa rechargeable batteries creating 12volts or technically 9.6volts since rechargeables are 1.2 and alkaline are 1.5.
Not sure how to connect it, ive tried connecting positive to the red wire and negative to all the pinkish colored wires with red dots on them. Nothing happened but a slight noise. Im trying to get all the lights to come on. dont know how. Pictures below of the chip, wires and power source. thanks http://postimg.org/image/fnlu02kel/ http://postimg.org/image/4xqyoefsx/ |
Connecting Power everywhere like this is the best way to fry the chip! Many of the wires are carrying low-voltage data signals.
Just adding Power will probably not show you anything on the display. |
Originally Posted by haio
(Post 88624)
I don't know why you want to Power it up?
hook it up to a cars wire harness, or get hold of the scematics for it. Without there are nothing you could do, even if you know electronics. Applying power by random will damage it! |
(Post 88624)
Just adding Power will probably not show you anything on the display. Replaced Intrepid cluster with the Black face/chrome ring Concorde cluster auto-stick. while clusters out I replaced all 10 cluster lights w/ blue LED's. Well to get polarity right I put it on my bench w/ 12v supply, I found the shared ground and the B+, and put in the LED's, if it didn't light, just rotated it 180 well I was sloppy, just trying to hold 12v, ground, twisting 194's, well ground wire kept slipping off, so in haste just assumed this one IC heat sink was ground...it was NOT..lol, gotta "SNAP", then checked everything and wired it right like 1st time. all LED's lit up, ok, SEEMS ok...put back in car and during day looked ok, but I must have popped a diode because 90% of all the little warning lights such as seat,oil,engine,trac,etc are on, flicker, not fully bright but still very noticeable, hate it. Going to either have to trace down the bad diode or reg...or hit the yard and get another PC board. Be Warned ;) http://i60.tinypic.com/vykr47.jpg http://i58.tinypic.com/mb4lnd.jpg PS: Sorry bout the crappy pic |
(Post 88670)
[QUOTE=Hw00d;88707]living proof here, and I supposedly know what I'm doing or so I'm told ;)
Replaced Intrepid cluster with the Black face/chrome ring Concorde cluster auto-stick. while clusters out I replaced all 10 cluster lights w/ blue LED's. Well to get polarity right I put it on my bench w/ 12v supply, I found the shared ground and the B+, and put in the LED's, if it didn't light, just rotated it 180 well I was sloppy, just trying to hold 12v, ground, twisting 194's, well ground wire kept slipping off, so in haste just assumed this one IC heat sink was ground...it was NOT..lol, gotta "SNAP", then checked everything and wired it right like 1st time. all LED's lit up, ok, SEEMS ok...put back in car and during day looked ok, but I must have popped a diode because 90% of all the little warning lights such as seat,oil,engine,trac,etc are on, flicker, not fully bright but still very noticeable, hate it. Going to either have to trace down the bad diode or reg...or hit the yard and get another PC board. Be Warned ;) can you simplify this |
