Load Leveling System/Rear Shocks
Old Oct 11, 2010 | 01:07 PM
Sierra8's Avatar
Default Load Leveling System/Rear Shocks
Does anyone know how this system works in general? Is there a pump somewhere in the PACs interior, is the system air or hydraulic and is there a way to test and see if this system is working? I've never noticed or seen my PAC auto level in the rear even when towing.
Old Oct 12, 2010 | 06:29 AM
busboy4's Avatar
Hi,
I checked my '05 MX manual and the shock unit is self contained - no pneumatic system (I had an air system on a Ford Windstar). And the remove/replace procedure reads like most normal shocks. The Monroe website lists the rears for an '05 Pacifica with AWD as a 40211 and lists it as a specialty shock. Here is a photo. Pricey. I had not looked at those but cheapest I found was RockAuto at $250 each. I agree that one wonders how you call it "load leveling" without an active system, but in the pickup and SUV world there are a number of shocks that claim load leveling ability. I think perhaps these shocks can just maintain normal height and performance over a wider load range. Some of the light truck load levelers have shock absorber encased in an external spring.
Old Oct 13, 2010 | 06:28 AM
busboy4's Avatar
Continuing the discussion: I spoke with a close friend who was educated by and worked many years for GM as an engineer. He said he believed these types of shocks have variable internal valving that allows the shock to increase/decrease its damping rate in response to load, without any external adjustment.
Old Apr 11, 2011 | 03:48 PM
kinville's Avatar
Regarding the load leveling shocks, would there be any adverse consequences for replacing them with regular shocks? Besides, of course, that the ride height would not stay the same when the rear is loaded.
Old Apr 12, 2011 | 08:58 AM
TNtech's Avatar
No, use the same shock type.
Old Apr 13, 2011 | 04:32 AM
kinville's Avatar
By this do you mean to use the same shock type as it was originally equipped with; ie the load leveling shocks?
Old Apr 14, 2011 | 10:49 AM
thatendswell's Avatar
When I bought my 08 Pacifica about two weeks ago, the left side (front and rear) was noticabley lower than the right, by nearly two inches. But it seems to slowly have corrected itself and is even now. Perhaps the load levelling system takes time to adapt.
Old Apr 14, 2011 | 03:38 PM
TNtech's Avatar
Yes, if you want to maintain the same ride quality. Not sure if standard ones will even line up to attache points.
Yes, about as exciting as watching a turtle race.
Old Apr 14, 2011 | 07:01 PM
Djinn-n-Tonic's Avatar
Yes, they will line up, but the standard shocks are too long...an average bump "Bottoms " out the shock and tears up the internals....They will be absolutely useless in a matter of a month.
kytna
Dec 22, 2011 05:59 PM
TandCfan
Oct 7, 2011 07:37 AM
gareth111278
Sep 20, 2010 11:18 AM
Voyager Pilot
Apr 29, 2009 08:04 PM
Fred D
May 1, 2007 05:38 PM
