message display
my message display isn't displaying, it beeps sometimes letting u know that u have amsg but it doesn't light up. we have cked the fuse box under the hood and none were blown. is there a buld for the dislay or something else causing it not to display. we leaving for panama this week if i could hear from u soon. thanks so much,
rhonda |
RE: message display
The EVIC uses a vacuum fluorescent display. It is serviced with the cluster.
RE: message display
under warranty take it to the dealer and have them check it out and replace the cluster assembly not under warranty gonan costa ya quite a few bucks
RE: message display
I have an 04 and mine went out around 42K. We don't have the extended warranty and the dealer said cost is $995 for the cluster. Not sure what installation will cost.
I called Chrysler customer service and they basically said since it is out of warranty I am out of luck. I raised a little h*ll because what engineer decided to integrate the entire cluster like that? And besides, what kind of quality is it when that goes out at only 42K? I will never buy a Chrysler again I can tell you that... |
RE: message display
Ummmm,that is why you buy an extended warrenty. Believe me Chrysler is not the only one to use this type of cluster. Check out the cost of a similar one in a GM,or Toyota. My god man EVERY carmaker has something can fail long before we think it should. Do you service the car with the dealer in question?
