New air filter
Old Oct 8, 2007 | 11:10 AM
jmcdolej's Avatar
Default New air filter
Can someone walk me through changing the air filter? I looked at it real quick at lunch and I am not exactly sure how to get the air box a part. I searched and found nothing. Thanks in advance.
Old Oct 8, 2007 | 11:16 AM
hambone's Avatar
Default RE: New air filter
Hi there, its a bit tricky but i got used to it.
You will have to follow the steps below:
1) unscrew both the screws that are attached to the throttle body flex pipe and the plastic air filter head
2) Unscrew the bolts/screws on the air filter cover (total 4 - 2 on each side)
3) carefully pull back the rubber flex pipe that connects to the throttle body and pull the air filter cover out. (requires some manuevering around)
4) follow same procedure back to hook it up.
Hope this helps.
-H
Old Oct 8, 2007 | 11:23 AM
jmcdolej's Avatar
I hope so too thank you!!!!!!!!!!11
Carlo60
Apr 7, 2011 03:45 PM
zlee1
Jun 23, 2006 10:14 AM
harryc8786
Oct 18, 2005 04:39 AM
Psyence
Jul 27, 2005 03:25 PM
lates
Mar 24, 2005 09:18 AM
