P0 457 and PO 456 - Ideas? Help?
Old Oct 1, 2019 | 04:30 PM
UberPacifica2005's Avatar
Unhappy P0 457 and PO 456 - Ideas? Help?
Hey everyone! Got a PO 457 - Fuel Cap and PO 456 - "Very Small Leak". So the fuel cap is a MoPar original and brand new from the dealership. I checked all the visible connects and things looked tight. However, when I pulled the cover off the evap canister area there was one hose that had receded. I pulled it and reconnected it properly.
When I started the 05 Pacifica it did throw the GasCap Odometer code, however, this time it seems a bit delayed. Am I on to something?
Where is the most common place on the 05 Pacifica 3.5 Touring to have a "small leak" in the evap system?
Thanks,
UberPacifica2005
Old Oct 1, 2019 | 04:49 PM
REBEL59's Avatar
Could be anywhere, some even report a crack forming on one of the plastic hose fittings on the fuel tank. BEST way is to have a smoke test done...That will locate the leak for sure without hours of visual inspecting that may not find the source.
Old Oct 1, 2019 | 09:08 PM
djetelina's Avatar
Agree w/ Rebel. My Pac drove over a large piece of concrete that was jutting out in a grocery store parking lot a few years ago. Was one hell of an impact, smashed the plastic tank up against the car body, cracked one or more of the plastic fittings going into the tank.
Was throwing codes, would not pass inspection, wound up finding these very small cracks with a smoke test, but the leak was very small and hard to spot.
UberPacifica2005
Jan 23, 2020 08:33 PM
duskyjewel
Aug 5, 2019 01:02 PM
rpcabergs
Jun 8, 2017 04:50 AM
bdevil
Mar 10, 2017 05:46 AM
jtmattison
Sep 17, 2011 01:36 PM
