Pacifica no spark issues
2007 Chrysler Pacifica ASD code shows up went though and checked everything new crank sensor and cam sensor checked all the wires, grounds and relays timing everything i went through and check everything n it all come back 100% i spent hours on this vehicle and still have no spark help me out
I have a 2009 Pacifica and it had the same problem. It would crank over but not start. If I bypassed the asd relay with a paper clip it would start fine. In the end it turned out that the asd control wire was broken about 5 inches from the fuse box. This is the wire that goes from the fuse box to the PCM. While I had this problem it had all sorts of symptoms. At first it would crank but not start. Then it would start and shut off randomly while driving. Soon after it would start, run for a couple minutes and shut off again. Finally it went back to not starting at all again. The wire that had a break was actually corroded internally. Just thought I would post this to help out the next guy. I'm sure I'm not the only one with this problem.
WillQRose
Oct 18, 2018 07:18 PM
LemonSebring98
Apr 17, 2011 08:54 PM
