PLEASE HELP!!! Drivers side lights not working
Old May 18, 2011 | 06:29 PM
Chris Walker's Avatar
Default PLEASE HELP!!! Drivers side lights not working
I just bought a used 2005 Chrysler Pacifica. Did not notice til last night that the drivers side taillight was out. Looked further and the two drivers side front running lights are out also.
Brake lights, and headlights are working fine. I switched the good bulbs from the passenger side over to the drivers side with no result.
Where do i start?
Old May 22, 2011 | 01:07 PM
Ive gotten the driver side running lights to come on, but they will only stay on for a few minutes.
I unhook the negitive battery terminal, unplug the wire harness from the fuse box and blow it out. Put it back together and they will come on. I take it out for a test drive and about 10 minutes of driving they will cut off and not come back on.
Anyone have any ideas??
Old May 23, 2011 | 10:44 PM
TNtech's Avatar
Sounds like the IPM has gone fruity. Or a ground is coming loose somewhere.
Old Jan 28, 2013 | 02:54 AM
revfast's Avatar
Im having a similar issue but with the passenger side headlight, did you find a fix for this ???
Old Jan 28, 2013 | 08:44 AM
The IPM more then likely needs to be replaced
Old Jan 29, 2013 | 11:26 AM
revfast's Avatar
what am i looking at as far as hrs needed to get this replaced and price of part ?
Old Jan 29, 2013 | 10:22 PM
parts price call your dealer and I dont have a listing for the book time either.
Old Feb 1, 2013 | 08:48 PM
revfast's Avatar
well what I did was reseat all of the relays and fuses on the fuse block in the engine bay, I also moved the fuse block out of its craddle by pressing all four tabs and reseated all of the connections in the back, two days running and I have yet to have the problem.
Old Feb 2, 2013 | 12:25 AM
it will return
Old Sep 14, 2021 | 08:17 AM
Daveh2020's Avatar
Where do i start?
So so where should I be looking in the fuses or is there something else
On the driver side marker front marker out rear running light out what would be the problem where to look
