Problem with Seat Setting/Auto Mirror
Old Jun 14, 2007 | 03:43 PM
SConn's Avatar
Default Problem with Seat Setting/Auto Mirror
I have noticed my mirror (driver side)does not return to the position programmed with my seat setting sometimes. It is getting a little annoying because I'm constantly having to readjust my mirror. My husband has seat setting #2, and he notices the mirror isn't going to where he set it either, so he has to adjust it. The seats are moving to the correct position, but the mirror isn't.
Is there a part going out? Has anyone noticed this problem?
I have an '05 Pacifica Limited, 26k miles FYI.
Thanks,
Stacee
Old Jun 14, 2007 | 03:46 PM
Default RE: Problem with Seat Setting/Auto Mirror
take it to the dealer
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.
THIS BULLETIN SUPERSEDES SERVICE BULLETINS 08-012-06, DATED MARCH 8,
2006, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE
HIGHLIGHTED WITH **ASTERISKS** AND INCLUDES A CORRECTED LABOR
OPERATION TIME.
SUBJECT:
Flash: Front Power Memory, Heated Seats and/or Adjustable Pedals Performance
OVERVIEW:
This bulletin involves replacing or selectively erasing and reprogramming the Memory
Heated Seat Adjustable Pedal Module, diagnosing and repairing a spread wire terminal in
the Integrated Power Module (IPM) and connecting the upper portion of the driver seat
adjuster track assembly to electrical ground as necessary.
MODELS:
2004 - 2006 (CS) Pacifica
NOTE: This bulletin applies to vehicles built on or after January 19, 2004 (MDH
0119XX) through and including February 12, 2006 (MDH 0212XX).
SYMPTOM/CONDITION:
The front power memory, heated seats and/or adjustable pedals may exhibit any one or
more of the following Symptom/Conditions:
· Heated seats do not get warm enough
· Become non-responsive (lock up) due to a software issue in the Memory Heated
· Become inoperative due to a spread electrical terminal in the IPM
· Become inoperative due to electrostatic discharge causing the Memory Heated Seat
Adjustable Pedal Module to stop functioning
Old Jun 14, 2007 | 03:51 PM
SConn's Avatar
Thanks so much!
Will this repair be done for free? And am I not able to refer to this bulletin when I take it in?
Old Jun 14, 2007 | 07:26 PM
u are under warranty they should know this already just describe to them what the prob is and that u saw a tsb with the related issues.
casper
Dec 6, 2014 04:37 PM
Jessech
15
Apr 5, 2014 08:49 AM
sjones
Mar 3, 2009 09:25 AM
sonic gihad
Jan 5, 2009 03:24 PM
tgragtop
Oct 12, 2005 02:59 PM
