Programing a new or used Chrysler Remote Car Starter FOB
Hi gang!
When I purchased my Pac last month, it came with 2 chipped keys (for the locks and rear lift) and 2 remotes to start the car (Chrysler/MOPAR brand, single button). I recently picked up another Key and was successful in programing that new key to the car (took less than 30 seconds to program the new key). I have a chance to get a used Chrysler Car Starter FOB and I’m looking for the procedure to program that car Starter FOB to my car. If I can do that, this will give me a total of 3 complete key sets (chipped key for locks and Remote Car Starter FOB). Anyone with info on this? Cheers!! |
OK, I think I may have found the programing instructions... Will post results when I get the Car Starter FOB in...
Cheers!! |
Just a quick update... Awaiting the arrival of my spare Transmitter.
The instructions I have seem to indicate that up to 8 Transmitters can be programmed (including the 2 that come with the MOPAR kit). Cheers!! |
1 Attachment(s)
OK, I got my new/used MOPAR Car Starter transmitter (purchased it on eBay) and it took me less than 30 seconds to program it to my Pac!!!
Attachment 2444 The instructions I was able to find included both the Owners Manual AND the Installation Manual (I have both in PDF format) for the MOPAR Car Starter. The Installation Manual had the Programming instruction on it. If there is interest for it, I'll post them. Anyway, here is the programing instructions: MOPAR Car Starter Transmitter (Key FOB) programming Instructions First, locate the Programming Button (should be zip-tied to the OBDII connector wiring harness, or close to it). It’s round, about 1/2” in Diameter and black in colour. Transmitter Programming:
That’s it! Takes less then 30 seconds to train the Transmitter to your car. Cheers!! |
remote start
Hello, I found two buttons under my wheel one is red another is black , maybe someone know which one is a programing button. Thanks for help
Originally Posted by viklogin
(Post 86269)
If that is an after market starter, or some other system has been installed, it may be different... Cheers!! |
Thanks for the info on programming a new remote. I just purchased an 07 pacifica and it only has the one remote start remote so im glad I can buy a second one. I just have one question. I didn't get any demonstrations or explanations on how to use the remote. I figured out one day that if I hit the button 3 times then it will start the car. Is that the only way it works? thanks in advance
Originally Posted by iage89
(Post 86560)
Hope this helps!! Cheers!! |
Remote starter help
After needed to put a new engine in my 07 Chrysler 300C, my remote start shuts off immediately after starting. Does anyone know what needs to be done?
Originally Posted by Grenadiers
(Post 65035)
https://i.imgur.com/PhEP7.jpg The instructions I was able to find included both the Owners Manual AND the Installation Manual (I have both in PDF format) for the MOPAR Car Starter. The Installation Manual had the Programming instruction on it. If there is interest for it, I'll post them. Anyway, here is the programing instructions: MOPAR Car Starter Transmitter (Key FOB) programming Instructions The MOPAR Remote Car Starter system ships with 2 pre-programmed Transmitters. The system can be programmed for up to 8 Transmitters in total. First, locate the Programming Button (should be zip-tied to the OBDII connector wiring harness, or close to it). It’s round, about 1/2” in Diameter and black in colour. Transmitter Programming:
Originally Posted by Coribabs
(Post 111400)
| All times are GMT -5. The time now is 03:53 AM. |
