Rear Wiper Arm Adjustment
Old Nov 4, 2010 | 08:05 PM
Blitzn's Avatar
Question Rear Wiper Arm Adjustment
The rear wiper arm on our 2005 Pacifica basically swung 180 deg from the horizontal position in a nice arc on the rear window.
On our 2008 Pacifica, the arm is angled downward about 10-15 deg so it clear a "crooked semicircle".
Does anyone know how to adjust this sucker - or remove and reinstall so it is level?
Many thanks!
-dennis
Old Nov 5, 2010 | 06:55 AM
busboy4's Avatar
Dennis,
I have not worked with my rear wiper, but it should be the same as up front. Carefully pop up the plastic cover at the base of the arm. Remove the nut that holds it on the shaft. Remove the arm from the motor shaft - can be tough. A little PB blaster can help. Once off you can rotate the arm a few "teeth" on the splined shaft of the motor to adjust the throw of the arm. Re-install the nut and close the cover.
calamity coyote
Jun 30, 2015 07:13 PM
TheAverageDan
Jun 3, 2015 05:02 AM
kdavidson
Apr 8, 2014 03:18 PM
notodd
Mar 12, 2012 02:47 PM
SpudlerT+CTouring
Oct 20, 2011 03:28 AM
