removal panel near traction swith and ashtray
Old Jul 19, 2007 | 04:39 PM
snailtek's Avatar
Default removal panel near traction swith and ashtray
unfortunately, i have two checks fell under the ashtray.. i need to remove that panel in order to get my checks.. i tried removing the ashtray cover to no avail instead broke it.. (another problem) hehe
thanks in advance
2004 Chrysler Pacifica with everything on it!
Old Jul 19, 2007 | 07:37 PM
xfire04's Avatar
Default RE: removal panel near traction swith and ashtray
void the check and go on
Old Aug 21, 2007 | 10:34 AM
charlesdixon's Avatar
i just installed sat. radio on my '04. i had to remove some panels to run the cables and whatnot in the same area you are talking about.
i would suggest you start by removing the panel under the steering col. (2 phillips screws on bottom side)
once that has been removed, you will get access to other screws holding the radio trim and center consol.
that's as far as i needed to go, but its a start for your project. good luck.
charlie
vernd
26
May 6, 2024 03:30 PM
tbird2340
Aug 9, 2011 09:57 PM
SARG
May 31, 2009 08:31 AM
fielderosa
Sep 28, 2006 10:52 AM
Jan 4, 2005 01:38 AM
