Replacing drivers door master switch module
Old Aug 29, 2017 | 02:03 PM
vitkh's Avatar
Default Replacing drivers door master switch module
Hello!
When replacing the main power windows/door locks module on the drivers door with the new one (or a used one) - does it need to be reprogrammed or re-flashed or is it simply plug and play? I need to replace it... 2008 Chrysler Pacifica... Thank you for your help.
Old Sep 19, 2017 | 02:17 AM
FromDownAbove's Avatar
Plug and play.
I would make sure you test your fuses before buying a new ddm. There is a fuse labeled IOD in the fuse box under the hood. Pull that fuse for a minute or two - this will reset the car's computer modules. A reset will most often fix issues with the ddm (power locks, windows, etc.).
asifakhtar
Sep 23, 2013 10:39 AM
ramonroad
Jun 19, 2012 04:12 PM
fsmclean
Dec 31, 2011 02:22 PM
zoron2008
Dec 4, 2009 11:41 AM
bobgfla
Dec 14, 2004 12:17 AM
