same problem, new post 04'pacifica no heat
I have researched other posts about a similar problem on my 04' pacifica w/ATC. The front blower does not work. So far I have checked the relay and fuse, both ok. I changed the blower control module behind the glove box. Still not working. Is there a fuse in line between the control head and the blower module? and If I bench test the motor is it strictly 12V on the high side or is it lowered through the control module? Any help would be greatly appreciated ... Brrrrrrr -20 degrees with the wind chill this morning[:o]
RE: same problem, new post 04'pacifica no heat
Update for Pacifica owners, FYI if you encounter the same issues be sure to test the blower motor before changing the blower control module. It will save you $77. I found that I had an output voltage of 11.75 vdc from the control module (old and new), I then removed the blower motor and hooked it up to a variable power supply set at 11.8 vdc and the motor hums and barely moves. New blower motor is on order.
