service code after waterpump replacement
Old Nov 16, 2010 | 09:28 PM
NWPacifica's Avatar
Default service code after waterpump replacement
New member here and here's what I got going on.
I just replace the waterpump on my 06' Pacifica. I replaced the timing belt and serpentine belt at the same time. filled engine back up with coolant and started it. It ran perfect, purred like new. Went for a test drive and I had a engine light(litterally picture of engine). Anyway it must be in some safe mode b/c you can drive it, but if you try to give it more that about half throttle it starts to miss, kind of like a rev limiter. B/F I put the timing cover on, I double checked the alignment of the cams and crank. They lined up perfectly as the old one b/f the change. I even rolled the engine over by hand to check for interfereance(mechanical) b/f I put it all back together.
I will get it on a code reader as soon as possible, any ideas?
Old Nov 16, 2010 | 11:47 PM
there are 1500 codes u take your pick find out the code first
Old Nov 17, 2010 | 06:53 AM
NWPacifica's Avatar
yup, thats next
jimG
Aug 24, 2016 10:34 PM
dnasty88
Jul 30, 2011 07:39 PM
Raindrop
Jun 20, 2011 09:41 PM
keyology
Feb 15, 2011 10:30 AM
car5car
Apr 8, 2007 07:32 PM
