Sirius Install with 07 MAST antenna
I will be doing a MOD on my 06 Pacifica that I've not seen done yet. I will be adding a 2007type sirius/MAST antenna. This is the new antenna you are seeing on all the 2007 chrysler models. Wish me luck, and hopefully I will get better reception instead of the window antenna. I'll let you know how it goes.
RE: Sirius Install with 07 MAST antenna
u will be wasting your time there are 2 different antennas one for sat one for radio.
The 07 antenna has the siruis SAT antenna and radio antenna in one. I will be disconnecting the integrated glass antenna and running new wire for that. I have all the correct parts now. I hope it's not a waste of time. Thanks
Install went great, it took me about 4 hours to complete. Hardest part was taking off all the panels to run the wires.
Does Haynes make a manual for the Pacifica, are there any service manuals out there for maintenance and for instructions on how to remove dash panels without damaging components? I want to set up my sirus as cleanly as possible, but i'm feeling a little shy since i don't even know where the clips on the plastic covers are set up.
I purchased a panel tool from crutchfield.com, this helped me pull the panels off easier. I would invest in purchasing the service manuals also. You can get it on CD-rom cheaper, either from chrysler.com, or E-bay. Good, luck and let me know if you have anymore questions in regards to the sirius install.
Hello, I'm new to this forum. I recently bought a 2006 Base
Pacifica. What kind of Sirius radio do you have? I have a Sportster 4 and I'm searching for installation ideas and options for better reception. The fm transmitter is terrible with this vehicle. Thanks, Tyr |
afmedic911,
What part number was the gps/combo antenna? I bought the kit for my 2007 Pac (82209764AD) and it came with a seperate gps ant and requires drilling. Will the combo ant. work with any Pac Sirius radio? Thanks for your help. |
| All times are GMT -5. The time now is 04:27 AM. |
