stop the shake
New to the site, just got a 2007 Pacifica, about 6 months ago and love it. I had a problem with the starter clicking some time and then start right up. After looking around on the big wide web., I Found that it was not getting a good ground to the motor, so I ran a 4 ga. Wire from neg. battier. Post to a bolt on the transmission and have not had a problem with that. Know the next problem is when I hit the brakes it shakes like when you have warped rotors. I changed the rotors and brake pads on the front but that did not fix it, I have no ABS lights on , at low speeds not much of a thing, but running on the interstate and having to get on the brakes it shakes a lot. Does anyone have a suggestion what I might be up against? Thanks in advance
+1. sounds like either tie rod ends or control arms to me. also grab yourself a repair manual and make sure all front suspension bolts are torqued to spec. a loose one can definitely cause that same shimmy.
97K15004WD
Aug 26, 2007 07:35 PM
