Transmission fluid compatibility
I’m doing a partial Transmission fluid change on my Pacifica. Can I mix Mopar ATF+4 and SuperTech ATF+4 (Walmart Brand)
Yes, both are licensed ATF+4. I like SuperTech because it is less expensive. No issues using for over 10 years.
Originally Posted by ggoose
(Post 115905)
I will only comment on ATF+4. It is synthetic and good for 100,000 miles under normal conditions. It may not say so on the bottle, but the licensing to call it ATF+4 makes it synthetic. Note, do not confuse licensed ATF+4 with ATF+4 compatible; not the same. The actual specification is MS-9602 and should also be present on the bottle.
| All times are GMT -5. The time now is 11:50 PM. |
