Transmission fluid compatibility
Old Oct 3, 2020 | 03:05 PM
Zweifel's Avatar
Default Transmission fluid compatibility
I’m doing a partial Transmission fluid change on my Pacifica. Can I mix Mopar ATF+4 and SuperTech ATF+4 (Walmart Brand)
Old Oct 7, 2020 | 11:33 PM
ggoose's Avatar
Yes, both are licensed ATF+4. I like SuperTech because it is less expensive. No issues using for over 10 years.
Old Oct 9, 2020 | 01:58 PM
Zweifel's Avatar
what about full synthetic ATF+4 and just regular ATF+4? Oreillys told me all transmission fluid is full synthetic but I don’t trust those Auto store works as much as a mechanic.
Old Oct 10, 2020 | 11:22 AM
ggoose's Avatar
I will only comment on ATF+4. It is synthetic and good for 100,000 miles under normal conditions. It may not say so on the bottle, but the licensing to call it ATF+4 makes it synthetic. Note, do not confuse licensed ATF+4 with ATF+4 compatible; not the same. The actual specification is MS-9602 and should also be present on the bottle.
Fayraz
16
Jul 30, 2014 08:44 AM
ShadowLight
Aug 14, 2012 07:59 AM
kgillespie
Mar 19, 2009 06:34 PM
Dave
Feb 23, 2008 09:54 AM
sebringpilot
Nov 7, 2006 03:52 PM
