Vacuum Gauge
Old Jan 20, 2011 | 12:51 PM
Sierrasan's Avatar
Default Vacuum Gauge
I want to temporarily hook in a manifold vacuum gauge to see if I can adjust my driving style to produce more mpg. The engine is the 3.5 on a 2005 AWD. Are there any unused taps on the intake I could use or what hose would be good to T into?
Old Jan 20, 2011 | 02:05 PM
it wont work the software in the computer will simply adj it back to where it needs to be
Old Jan 20, 2011 | 03:18 PM
Djinn-n-Tonic's Avatar
I'm assuming you just want to MONITOR engine vacuum??? Like an Older Muscle car with a Dash mounted VAC GAUGE??? Or a Mid 70s Newyorker or Cordoba with the "Fuel Minder" system in the Left side Fender mounted turn signal pod??
Monitoring is possible, Making Changes , other than the weight of your left foot, is not.
Although....I wouldnt recommend this. There are no "Obviously" un-used ports, and the ones that are there are for "Critical" function. For example..."Tapping" a MAP hose would be a mistake. I wouldnt want to open up a Booster Hose, simply for the safety aspect, and the only other viable point I can think of at the moment would be The cruise Servo, which may cause other problems .
Old Jan 20, 2011 | 05:27 PM
Sierrasan's Avatar
Yes it would be to monitor the vacuum.
Old Jan 20, 2011 | 06:10 PM
buy a scan gauge it plugs into the OBD port and it will give u instant MPG and the vac u also wanted plus many more sensors readings.
http://cgi.ebay.com/ebaymotors/ScanG...item27b7f22aed
funjon1
May 6, 2011 06:24 AM
Dangermouse
Jan 20, 2010 07:32 PM
anrie
Jun 11, 2008 09:54 AM
BillMarts
Mar 25, 2008 12:53 PM
donnyohs
Nov 23, 2007 10:09 AM
