Wooot...... Few more error codes. P0700 & P0846
Old May 18, 2013 | 04:59 PM
Raindrop's Avatar
Default Wooot...... Few more error codes. P0700 & P0846
Hi,
So my wife was driving 2006 3.5L Pacifica the other day and transmission became stuck in a lower gear causing high reving sounds from engine. Also check engine light illuminated. Car was drivin back home in slow speed and when I scanned for error codes it gave me P0700 and P0846. Automatic transmission fluid level is ok. Now I know these error codes have something to do with malfunction of Transmission Fluid Pressure Sensor/Switch. But I have 2 questions if someone has experience with this issue.
1) Chrysler has a TSB out for error code P0846. TSB number is 2100905 and release date is 03/22/2005. Does anyone know of solution mentioned in that TSB?
210090503/22/2005
2) Is there any chance that alternator has anything to do with this malfunction?
Thanks for reading.
210090503/22/2005
Old Jun 1, 2013 | 11:40 PM
Raindrop's Avatar
Update here:
So I went to get alternator tested and found that my 2 years old battery is dead. I had battery replaced under warranty. I am thinking may be low voltage triggered the codes P0700 and P0846. So I cleared the codes and so far car is running fine without any transmission issue or check engine light.
Old Aug 17, 2019 | 01:39 PM
Emct's Avatar
[font][font]Hallo, können Sie mir mit einem Code für dieses Radio helfen: [/font][/font]
[font][font]Chrysler SEBRING[/font][/font]
Old Aug 18, 2019 | 04:14 AM
Chrysler SEBRING
TCAAA1004K5706 code is 3551
Old Feb 23, 2020 | 01:28 PM
Dusan Mladjenovic's Avatar
Default Can anyone help with radio code
Can anyone help with code? Thanks
Old Aug 15, 2020 | 10:06 AM
Blopopop's Avatar
Default limp mode p0700
P0700 code: My 2005 Town and Country wouldn't shift in hot weather after driving a while, so I went into the fuse box and replaced the EATX Safety Shut Down Relay for $20. Problem solved! Thanks, Occam's razor!
sebringing
Apr 8, 2015 05:30 PM
Timx117
Aug 7, 2014 11:51 PM
Gray06TCmb
Apr 15, 2010 06:14 PM
Wiesenpilz
Jun 7, 2009 12:03 PM
VanJockey
Apr 7, 2008 08:58 PM
