xm/ sirrus radio
Old Jan 18, 2011 | 06:03 PM
msarles1's Avatar
Default xm/ sirrus radio
my 06 pacifica has no sirrus from the factory, i found a factory setup on ebay is it possible to make this work ?
Old Jan 18, 2011 | 06:32 PM
Djinn-n-Tonic's Avatar
I'm sure ther is some way to do it, But be prepared for a HAssle....
Biggest challenge will be "INTERFACE".
Keeping as simple as possible...Your vehicle has a Communication network built into it .....So all of the Various Control Modules can talk to each other. The radio is considered a "MODULE" ..and will have to be connected to the communications "BUSS".
If you are planning this project without a trip to the Chrysler Dealership for Finalization....Forget it...
Although I do understand that the "HANG-ON" or ADD-ON" units contribute greatly to the UGLY FACTOR....It may be a better alternative....
Old Jan 19, 2011 | 06:03 AM
busboy4's Avatar
You can take a look here. Put in your make/model/year and under audio/visual you will see the sirius radio kit and installation kit. By selecting either item you can view "installation instructions" and have a look at what is involved. The instructions are very detailed but the process is a large one requiring a lot of dis-assembly, drilling holes in the roof etc. Certainly doable but take a look at what the job entails first.
Good luck with it.
pacman069
Nov 16, 2019 10:58 AM
Petco
Oct 31, 2018 10:08 PM
