05 No Crank
Old Jan 27, 2021 | 06:01 AM
DanielChap's Avatar
Default 05 No Crank
05 with no crank problem after transmission failing. I made the mistake of running low on transmission fluid and started to hear sounds of clanking from engine compartment. I kept using stop leak and fluid after noticing a significant leak. The noise after 3 days stopped and so did my transmission. When shifting into gear I only found a change in idle speed and I thought it would be a good idea to change the wiring harness. I used an 04 from another vehicle to change and when splicing what I didnt remove from the 04 I found and sealed a hole in my transmission. After reconnecting all wiring I have no crank. Then I found a note regarding a bad started on the dash of the 04. What can I do now?
Travis Wilkerson
Jan 28, 2020 05:23 PM
den458
Jun 19, 2019 05:25 AM
2005Cruiser
Aug 20, 2018 08:46 PM
gnmike87
Feb 10, 2012 07:58 AM
racergirl21
Aug 27, 2010 06:39 PM
