2004 PT Cruiser base Replaced PCM and now have new codes PO113 and PO706
Old Sep 6, 2021 | 04:33 PM
kehewkid's Avatar
Default 2004 PT Cruiser base Replaced PCM and now have new codes PO113 and PO706
Hello!
We had to replace the PCM on my daughter’s 2004 PT Cruiser base. When we did, it immediately gave us two brand new codes. PO113 and PO706. The car runs for awhile and then quits. It was overheating before we replaced the PCM, so we also replaced the radiator fan. We’re not sure if these codes are showing new problems, or if it could be the new PCM, which was refurbished by carcomputerexchange.com. Ideas or opinions would be appreciated. Thank you!
Old Sep 6, 2021 | 04:41 PM
kehewkid's Avatar
Default Those Os are zeros! :)
Sorry!
Old Sep 6, 2021 | 05:53 PM
p0113 intake air temp high did you plug the sensor back on on the air filter housing you took out to replace the pcm.
p0706 chk shifter signal could be a random code the light is likely on due to the intake air temp being unplugged .
Old Sep 6, 2021 | 06:39 PM
kehewkid's Avatar
Thank you! We’ll check those things first. It would be awesome if that’s what it is. I appreciate your help. I’ll let you know!
mkovacs
Jul 15, 2022 03:11 PM
Timo13
Sep 12, 2020 04:35 PM
mockrant
Dec 19, 2019 08:51 PM
Petar Å ank
Sep 23, 2018 04:18 AM
jacmates
Nov 7, 2015 10:55 AM
