2009 Chrysler PT Cruiser Won't Crank
Old Oct 11, 2020 | 07:13 PM
Carzane0144's Avatar
Default 2009 Chrysler PT Cruiser Won't Crank
I have a 2009 Chrysler PT Cruiser. I had tried to start it today and found that a soon as I started the car the display went black and no crank turned.
I could not jump start the car. I went and got the battery checked and charged. The display was back on and everything seemed to work. i started the car and again, the display went black, no cranking. The battery seems to be low again too.
Any suggestions?
Old Oct 12, 2020 | 10:24 AM
ggoose's Avatar
How old is the battery? If it is over 5 years old, I would suggest replacing it regardless of the battery check. The TIPM monitors the voltage and if not sufficient will not activate the relay to start the engine and if low enough, will not activate the display.
Old Oct 12, 2020 | 12:56 PM
The batter is newer than 5 years. I am going to take it out again and see if it has a bad cell tomorrow.
Old Oct 12, 2020 | 08:14 PM
ggoose's Avatar
If you have a voltmeter, the battery should read between 12.4 volts and 12.6 volts for a fully charged battery. This is a quick test and is not as comprehensive as a load test.
Old Oct 14, 2020 | 07:14 PM
Just got a new battery. once again, the display came on. the clock started ticking. I turned on the car and it made a tapping noise for maybe 1 second. but now the battery seems completely drained. no cranking. no power whatsoever
Kat Blum
Oct 7, 2020 11:03 PM
paulstevens
Aug 26, 2016 11:53 AM
cpk
Jun 30, 2012 08:19 AM
gameboy2901
Dec 20, 2009 05:26 AM
gameboy2901
Apr 24, 2009 06:43 AM
