Can a faulty PCM cause intermittent problems?
Can a faulty (failing) PCM cause erroneous any of the following problems:
1. Oil pressure light for low oil pressure (P0522) - had checks done for leaks (none), oil pump working fine, oil level within range, even replaced oil sensor just to be sure.
2. Transmission fluid low intermittent error (PP0741) - same cannot detect any root cause or issue.
3. The GPS calibration light comes on and off intermittently.
Thanks.
Thanks.
Dank442
Aug 7, 2014 08:04 PM
jtminnc
Oct 31, 2010 07:08 PM
